Another "folder re-naming" task
SnowdogPostNovember 26, 2024, 18:56
Normal topicAnother "folder re-naming" task
Okay, this is a bit of a weird one. I don't think I've had to do this before & I might never have again.
The issue is this: I have a set of folders. I've added 00 to the folder name & I'd like an action that would replace the 00 with the disc number, when the tracks are loaded into Yate.
I assume I can't do this "out of the box" in Yate?
I already have an action that changes 00 (or 000 if it's a big set) in the Album title to the disc number, which I use a lot, but I've never had to do it to folders before. (Although if I had an action, it might be something I'd routinely do in future.)
I've attached a screenshot, which hopefully will illustrate the point.
The folders are currently in amongst others in a containing folder & are the ones selected in blue. I could put them into a separate sub folder whilst I run the action, but if I'm sending the instruction from the tracks in Yate, I'm assuming it won't matter that they're in with other folders.
Thanks. 🙂
The forum is messing up this thread so I'm including the action link here:
Download: https://2manyrobots.com/actions/Rename-first-00-in-folder-with-disc-pad2.zip
Mingle Forum by Cartpauj | Version: 1.1.0beta | Page loaded in: 0.006 seconds.
