Additional Questions about Yate IDs...
danjewettPostMarch 1, 2025, 23:01
February 20, 2025, 17:05
Normal topicAdditional Questions about Yate IDs...
I am experimenting with Create Database Utility on a smallish batch of files. I'm finding that the album IDs insist on referencing a database that no longer exist when I double click the ID in the album database.
I've used the Yate IDs action function to clear all the IDs from the files which seems to work, but if I run the batch again to recreate the IDs, I still get the error:
Error reading /Users/dan/Music/ether_track_db.csv
The file doesn’t exist.
The Create Database Utility has a new db name in its configuration but the recreated IDs insist on referencing the deleted db.
If I remember correctly, when I first did this, and double click on the album ID in the album database, the corresponding tracks would open in the track database. Am I remembering this wrong?
Thanks,
Dan J.
danjewettPostMarch 2, 2025, 09:51
Ah! Found the issue was I still had the old value set as the default DB in Database settings.
2MR2PostMarch 2, 2025, 10:12
Sorry for the slow response. I had to rebuild my email accounts in Apple Mail.
I'm glad you found the issue.
