Multiple ARTISTS and ALBUMARTISTS fields
DebutantPostMarch 28, 2025, 10:11
September 21, 2024, 11:05
Normal topicMultiple ARTISTS and ALBUMARTISTS fields
I was reading Navidrome's tagging guidelines to try to setup Yate for it, but as far as I understand it's currently not possible because Yate doesn't support multiple ARTISTS & ALBUMARTISTS fields.
It there any workaround ? The goal is to be able to easily tag for example:
ARTIST: David Guetta feat. Kelly Rowland
ARTISTS: David Guetta
ARTISTS: Kelly Rowland
2MR2PostMarch 28, 2025, 10:59
Yate support multiple in artists, album artists and every other field where it makes sense.
You have to read up on the multi-value delimiter which is by default ;;;
You can use Help>Search Yate help to locate the following articles:
Multiple Items and Multiple Values
The Multi-Value Delimiter, Fields and Application Lists
... and far more. Every action statement as well as the UI is multi value aware. Lists can be generated, manually or automatically so that you can use the menu to the right of a field to append values:
See the help for Settings-Lists for additional information.
All multi value items are properly encoded for the appropriate audio file type when the files are written.
As far as featuring goes there are multiple variants ot there: featuring, feat. ft. and ft to name a few. There are actions on the resources web page to convert featuring sequences to multiple artists properly encoded.
Basically, using the application defaults an album artist field of Jack;;;Jill represents two artists: Jack and Jill
With few audio file exceptions, the ;;; sequences are replaced with appropriate encodings in the files.
DebutantPostMarch 28, 2025, 12:28
I did create two custom fields ARTISTS and ALBUMARTISTS and used ;;; but it wasn't read correctly by Navidrome so I was persuaded the cause was on Yate side.
But it turns out Navidrome was the culprit. So sorry for the trouble.
2MR2PostMarch 28, 2025, 12:31
No trouble. Those custom fields will definitely mess up the files. Certainly FLAC files where those are the standard mappings.
