Data Validation Error
DJunpridictabullPostMay 26, 2026, 12:03
Normal topicData Validation Error
I recently purchased a new MacBook Pro and a new 5TB external hard drive. I installed Yate, but I am now receiving the following errors:
“Data Validation Error: Destination base folder — The value is not a path to an existing folder”
I am also receiving a message stating that certain files had move errors.
Could you please assist me with correcting the destination folder/path settings? I believe Yate may still be pointing to an old or invalid folder location.
Thank you
2MR2PostMay 26, 2026, 12:13
I'm not sure what action you're running. Move to Alpha Take Two - Special?
More than likely the action has retained path information. Start the action with no loaded files. This will display the config. Fix the bad path in the config panel.
DJunpridictabullPostMay 26, 2026, 13:01
Thank you for the response. I followed your suggestion by starting the action with no files loaded and updating the bad path in the configuration panel. Unfortunately, I am still experiencing the same issue and receiving the same errors afterward.
Please let me know if there is anything else you would recommend trying. I appreciate your help and time.
2MR2PostMay 26, 2026, 13:08
I assume that you are now only getting the Move Error and not the Data Validation Error??? If so do you get the error for all files?
Go to the Action Manager and select the action you are running. From the context menu do an Export. Export the file as a zip.
Go to Settings - Runtime Settings. Select the settings for the action you are running. Export the set (=> control)
Send me both zip files.
DJunpridictabullPostMay 26, 2026, 14:29
I appreciate your help. I revisited your initial suggestion and successfully implemented it this time. I appreciate your assistance once again.
