Delete specified text from field
J00pPostNovember 25, 2015, 13:00
November 25, 2015, 17:51
Normal topicDelete specified text from field
How can I make an Action to delete a certain text string from a field (for example the title field)? I want to specify the text after a prompt.
Where can I learn to make Actions the best?
2MR2PostNovember 25, 2015, 13:18
Normal topicRe: Delete specified text from field
The following two lines will prompt you for a text string and then will delete the string in Title.
Prompt for Text "Remove the following text from Title" save text to Variable 1
Replace "\v1" in the Title field with ""
Note that the forum auto mailer removes backslash characters. The Variable specification in the Replace statement has a backslash before the 'v1'.
The best way to learn about actions is to read the following help topics on the main help page:
Actions
How Actions Execute
Variables
Escape Sequences
There are also quite a few fairly well documented actions on the Sample Actions web page (accessible from the Help menu).
BTW: Unless you want your action to do more than the above, you can do it completely from within the Multi Field Editor.
