Discogs OAuth Setup Failed (code 400)
afominPostMarch 16, 2016, 15:57
March 16, 2016, 19:43
Normal topicDiscogs OAuth Setup Failed (code 400)
Hello,
I didn't find any previous mention of this problem.
When I try to authorize Yate through Discogs wizard, the following OAuth error happens (see the screenshot attached).
However, I succesfully completed the same procedure a couple of days ago (I've just did some clean-up and reinstalled most of m software – that's why I'm doing it again now).
Why does it happen? Any suggestions?
I intend to buy a license, so hope it's not a bug...
Thanks in advance.
afominPostMarch 16, 2016, 17:54
Normal topicRe: Discogs OAuth Setup Failed (code 400)
Well, that's what I've found so far.
Discogs made its API HTTPS only according to this thread.
I used Charles to analyze HTTP requests issued by Yate.
I'm not an OAuth pro, but it looks like a bug in Yate networking layer.
The first request is OK:
POST /oauth/request_token HTTP/1.1
Host	api.discogs.com
Content-Length	0
Connection	keep-alive
Accept	*/*
User-Agent	Yate/3.11 +http://2manyrobots.com
Authorization	OAuth realm="", oauth_consumer_key="<a key>", oauth_signature_method="HMAC-SHA1", oauth_signature="<a signature>", oauth_timestamp="<a timestamp>", oauth_nonce="<nonce>", oauth_version="1.0"
Accept-Language	ru
Accept-Encoding	gzip, deflate
The response is 302 Found:
HTTP/1.1 302 Found
Content-Type	text/html
Content-length	0
Connection	Close
Location	https://api.discogs.com/oauth/request_token
Yate issues another request, but the verb is GET, not POST. Moreover, there aren't any OAuth headers anymore...
GET /oauth/request_token HTTP/1.1
Proxy-Connection	keep-alive
Accept	*/*
Accept-Language	ru
... And of course it results in 400 Bad Request.
HTTP/1.1 400 BAD REQUEST
Server	nginx/1.8.1
Date	Wed, 16 Mar 2016 21:23:26 GMT
Content-Type	text/plain
Content-Length	408
X-Discogs-Media-Type	discogs.v2
Access-Control-Allow-Origin	*
FYI: mapping requests from HTTP to HTTPS via Charles changes the error to 401 Unauthorized (which is quite expected due to invalid signature).
Do you guys have any plans on fixing this issue?
Regards,
Alexander
