Can I add my own field?
deadman36gPostJuly 14, 2016, 12:30
July 14, 2016, 01:21
Normal topicCan I add my own field?
I am curious if I can add my own fields here
View post on imgur.com
I would like to add VBR and CBR fields
2MR2PostJuly 14, 2016, 12:46
Normal topicRe: Can I add my own field?
You cannot add components to the built in editing panels. However you can have ten Custom Panels. You can easily recreate the Audio Panel on a Custom Panel with added fields. A custom field can be pretty much any Yate field or named comment, UDTI or UDURL. If you store the individual VBR, CBR values as UDTIs they can be displayed. The values are static and the space overhead is virtually zero.
However, on the standard Audio Panel, you will see the bit rate in the Audio Information panel whenever a single file is selected.
deadman36gPostJuly 14, 2016, 12:52
That is awesome. I have previously been using Metadatics and adding either a VBR or CBR tag to all my MP3s. Is there a simple way to just add that tag to selected files?
2MR2PostJuly 14, 2016, 12:57
No reason why you can't. You can even write a tiny action to extract the value from the property if you want.
