Yate --> iTunes grouping not working anymore
audionomPostNovember 7, 2016, 19:07
September 21, 2014, 09:34
Normal topicYate --> iTunes grouping not working anymore
Hi. After iTunes latest update, information tagged in 'Grouping' now appears under 'Work'.
Any ideas on how to fix this? / What might cause the problem?
(I'm running Yate 3.14.0.1)
2MR2PostNovember 7, 2016, 22:11
Normal topicRe: Yate --> iTunes grouping not working anymore
Well they broke the ID3 specification. 🙁
Prior to the latest iTunes release they did not support the "new" classical fields directly in any format except m4v. Yate could manually set the information, but it was not kept in the files. So in mp3 files, Yate plugged the Work field manually.
They've now decided that the ID3 Grouping field is mapped to Work in iTunes. This is idiotic as they still have a Grouping field in the library and it essentially damages all mp3 files which have Grouping metadata. This is ridiculous as they could have added a UDTI or even a non standard text field which they have done in the past.
Take any mp3 file which has a Grouping. Add it to iTunes directly. ie. Yate not involved. You'll see that they've placed the Grouping metadata into Work. They are still not writing the Movement Name or Number.
Unfortunately, I can't control what they do when they read an mp3 file. 🙁
I'm not sure how to get around this. Other players correctly use Grouping so we can't simply map the field elsewhere. If you manually set Grouping in iTunes, it is no longer written to the file.
I can file it is a bug report but I'm pretty sur I know where that will end up.
I can manually set Grouping in the library, but that will be a weak solution as well.
Argh!!!!!
2MR2PostNovember 8, 2016, 09:52
There's a new sticky post on " iTunes 12.5.2 (or greater) and Grouping Metadata". I suggest running one of the two "Preserve Grouping" actions in the resource area to make sure you don't lose metadata. If you edit the Work name in iTunes you will lose the Grouping metadata in the file.
