How can i get the Value of some Tags
niktofashPostMarch 20, 2017, 09:41
March 20, 2017, 13:27
Normal topicHow can i get the Value of some Tags
can you please help me to get the Values from some Tags: RELEASECOUNTRY, Discogs Release Country.
Nikto
2MR2PostMarch 20, 2017, 10:15
Normal topicRe: How can i get the Value of some Tags
The Discogs Release Country will be on the UD Text editing panel.
If you want you access the value in an action you can use a 'User Defined Fields' statement or read the value directly via an escape sequence:
\^Discogs Release Country^ (backslash before the first ^)
You can also add it to a text field in an action via the Insert Common UDTI context menu item.
niktofashPostMarch 20, 2017, 10:47
Ok, Thanks!!!
And the Value of RELEASECOUNTRY? On the same way?
2MR2PostMarch 20, 2017, 10:54
Yes. You can access any UDTI this way. Yate maps the FLAC version of the tag to DISCOGS_ALBUM_RELEASECOUNTRY and hides it as it is a normalized mapping across audio file types. However, if you have older values named RELEASECOUNTRY you can access them in the same manner.
niktofashPostMarch 20, 2017, 11:31
Thanks a lot 🙂
