Maximum iTunes Grouping-Work Name Compatibility and Track No. Issue
jakeokeefePostMay 10, 2017, 19:30
April 29, 2017, 23:30
Normal topicMaximum iTunes Grouping-Work Name Compatibility and Track No. Issue
When I have Maximum iTunes Grouping-Work Name Compatibility enabled in preferences, the track number field doesnt work properly. For the field Track Number X of Y for example, Y is never saved, but X is.
Any preference changes i should make?
2MR2PostMay 10, 2017, 19:46
Normal topicRe: Maximum iTunes Grouping-Work Name Compatibility and Track No. Issue
Well the track field certainly has nothing to do with that option. I can set Y when not linked to iTunes. When I change Y and I'm linked it changes in iTunes. I can't find a scenario where it doesn't work. I'm missing something here.
How are you editing Y? In the Info editing panel? Inline in the file list? Are you linked to iTunes? Where is it not changing?
jakeokeefePostMay 10, 2017, 19:49
Editing it in the Info editing panel. It worked just fine until i turned on the gouping option. now it leaves the field blank. it only works now if i am linked to itunes, not if i edit a file before importing it to itunes.
2MR2PostMay 10, 2017, 19:54
Okay. You load a track and don't link it. You enter a number in the 'Track Of' field and nothing happens? I must still be missing something
jakeokeefePostMay 10, 2017, 20:01
Nope, my mistake, I forgot i was using an auto script to convert flac to mp3. i thought i was editing my mp3s, but i was editing my flacs. My error is in my convert script.
2MR2PostMay 10, 2017, 20:03
Phew 🙂
jakeokeefePostMay 10, 2017, 20:08
now i have to get intouch with the guy who wrote this script years ago or figure out how to add this conversion support. good to know it wasnt yate.
2MR2PostMay 10, 2017, 20:13
Yate has a copy metadata function. You can load the FLAC and MP3 versions at the same time and copy all the metadata from one to the other. The Actions menu has a Copy Metadata submenu. The main help page has a topic called 'Copying Metadata from One Album to Another'.
jakeokeefePostMay 10, 2017, 20:28
ok ill give that a look. it is less automation than what i want, but it may be better to have a hands on approach to it. thanks for your help, love this program
