"Show Discogs Release" broken link
roennowPostMay 23, 2017, 06:16
May 23, 2017, 10:09
Normal topic"Show Discogs Release" broken link
Example:
Instead of opening https://www.discogs.com/Greg-Beato-Untitled/release/8661109 it will open https://www.discogs.com/release/https://www.discogs.com/Greg-Beato-Untitled/release/8661109
I only use this function when Yate for some unknown reason doesn't attach the artwork from a release so it hasn't been a big issue for me but thought i would mention it.
2MR2PostMay 23, 2017, 07:01
Normal topicRe: "Show Discogs Release" broken link
Indeed. The code attempts to have a lot of compatibility with other taggers by synthesizing the URLs when necessary. It was based largely on older Discogs addresses which were not https based. I've updated the code to allow https as a valid prefix and it works as it should now.
The next time the artwork import doesn't work for you please send me a Discogs Release ID so I can figure out why.
Thanks for reporting this. The fix will be in v3.16.1
