Action – Only move if fields are not empty ?
PowderPostMay 28, 2013, 16:37
Normal topicAction – Only move if fields are not empty ?
Is it possible to create an action which checks if the fields Album Artist, Album, Publisher, Year and Custom »CATALOGNUMBER« are not empty and only proceeds when true.
I would Yate like to rename the folder / files. So it would be great to have an action for than, instead of manually checking. This would be useful on releases which are not listed on Musicbrainz / Discogs.
clickjoyPostMay 31, 2013, 00:21
April 29, 2013, 20:42
Normal topicRe: Action – Only move if fields are not empty ?
Try "Exists Test" followed by "Test"
Exist Test - check fields XYZ, click "Exists"
Test - If True, Run [rename action]
Basically, Exists Test says "If these fields exist (are not empty), send "True" to next action". The next action (Test) says "If I get "True", then run another action."
You may need to use the User Defined Fields action beforehand in order to copy your custom field to a Variable that can work with the Exist Test action.
