Show Discogs Wizard: Focus Issue
PowderPostSeptember 22, 2017, 11:08
Normal topicShow Discogs Wizard: Focus Issue
when clicking the «Discogs Wizard» icon in the menu-bar it sometimes (often) happens that it does not have the focus and appears behind the main Yate window, which is quite annoying.
On the screenshot I moved the main Yate window a bit down, the Discogs-Wizard window is completely hidden when this happens.
2MR2PostSeptember 22, 2017, 11:37
Normal topicRe: Show Discogs Wizard: Focus Issue
What version of the OS are you running on?
PowderPostSeptember 22, 2017, 11:39
I’m running macOS 10.12.6 with latest stable Yate (fresh install).
2MR2PostSeptember 22, 2017, 11:46
Thanks. I'll take a look at it.
2MR2PostSeptember 22, 2017, 12:07
I stopped testing after 50 tries. I cannot duplicate the issue. I am running on the High Sierra GM so it is possible that there is an OS difference. However, I've checked the code and I can't see a case where the Discogs window is not told to 'come to the front'. Unfortunately I can't test on 10.12 as I'm travelling and I only have the one OS on my laptop. So, it's either the OS or I'm missing some sequence which makes it happen. If you can't think of something I'm missing I can have another look at the end of the month.
PowderPostSeptember 22, 2017, 14:25
Thanks for looking into it. If I find a way to reproduce it I will let you know. For me it looks like it is random – tagged 50 releases today, and every 5th time or so this happened.
