Get musical key using KeyFinder
PowderPostJune 5, 2013, 06:24
Normal topicGet musical key using KeyFinder
To get the musical key of a track you can use the free software KeyFinder, which can be called from Yate.
1) Download KeyFinder from here: http://www.ibrahimshaath.co.uk/keyfinder/ and install
2) Download the script: https://gist.github.com/Powder/5712869/raw/ce2e7d731288ac32af816e9a6009e4cbed7ff5e4/getkey.sh
3) make the script executable using chmod +x getkey.sh
4) To call it from Yate create a new Action and add the following functions:
Run external script and pass File as Parameter, save results to Variable1
then you can copy the value from Variable1 in Initial Key using the copy function
Mingle Forum by Cartpauj | Version: 1.1.0beta | Page loaded in: 0.005 seconds.
