iTunes_CDDb Tag?!?
sarvajanikPostJune 15, 2018, 02:40
April 7, 2017, 04:19
Normal topiciTunes_CDDb Tag?!?
I've grown comfortable with the workflow of using XLD to rip my CDs and managing all the metadata with Yate. And I've recently started using Audirvana to playback my entire collection too. But noticed something strange there.
Amongst the tags, I see a weird alpha-numeric code as part of the comments field within files that have nothing in the comments field actually. At 1st I thought it was Yate forcing through some MusicBrainz ID or some such—but then, it turned out to be XLD.
Yate being my primary choice for metadata editing, I wish to know how I can get rid of this particular tag. Because apart form Audirvana, it seems to be appearing even in Kodi now.
Thanks for all the help in advance.
This is a dump of the metadata of a file that was ripped using XLD:
General
Complete name		: /Volumes/Macintosh HD/Users/Sarvajanik/International Soundtracks/Coco (2017)/Disc 1 - English Version/01-01 Remember Me (Ernesto De la Cruz) - Robert Lopez, Kristen Anderson-Lopez feat. Benjamin Bratt.aiff
Format			: AIFF
Format/Info		: Apple/SGI
File size		: 21.5 MiB
Duration		: 1mn 49s
Overall bit rate mode	: Constant
Overall bit rate	: 1 653 Kbps
Album			: Coco
Album/Sorted by		: Coco
Album/Performer		: Germaine Franco, Adrian Molina, Robert Lopez, Kristen Anderson-Lopez
Part/Position		: 1
Part/Total		: 3
Track name		: Remember Me (Ernesto De la Cruz)
Track name/Position	: 1
Track name/Total	: 11
Grouping		: English Version
Compilation		: Yes
Performer		: Robert Lopez, Kristen Anderson-Lopez feat. Benjamin Bratt
Composer		: Robert Lopez, Kristen Anderson-Lopez
Publisher		: Walt Disney Records
Genre			: Soundtrack
Recorded date		: 2017
Cover			: Yes
Cover type		: Cover (front)
Cover MIME		: image/jpeg
Media Type		: Music
File type		: AIFF
iTunes_CDDB_1		: 6B1A4835+504801+53+150+8346+16275+21911+30326+43447+47255+52491+64906+70429+79707+92041+100237+108166+113802+122217+126010+131246+143661+149185+158310+170559+188334+201601+214944+230537+242833+257665+263963+269717+275001+286845+294999+307338+321142+326231+334122+335733+346498+350736+354906+366390+372008+393367+404024+414634+428430+437438+445462+456827+465952+474235+478747
iTunes_CDDB_TrackNumber	: 1
Audio
Format				: PCM
Format settings, Endianness	: Big
Duration			: 1mn 49s
Bit rate mode			: Constant
Bit rate			: 1 411.2 Kbps
Channel(s)			: 2 channels
Sampling rate			: 44.1 KHz
2MR2PostJune 15, 2018, 07:39
Normal topicRe: iTunes_CDDb Tag?!?
I'm assuming that you're talking about the 'iTunes_CDDB-*' items. If so, you can more than likely see these items on the UD Text editing panel. From there you can manually delete the items. Alternately, in an action, you can use the User Defined Fields statement to remove them all:
Remove all User Defined Text Items with prefix 'iTunes_CDDB_'
Unfortunately the way XLD represents the tags in their list may not be the same as they are represented in the files. So my choice of 'iTunes_CDDB_' as the name may not be correct. The UD Text panel should give you the 'real' representation.
If for any reason you can't see the items, do the following: On the Preferences-General-Common panel, make sure that 'Verbose log raw data' is checked. Select one of the tracks with the undesired metadata and do a File>Log>Log Data. Save the displayed information to a text file, zip it up and send it top us as support@2manyrobots.com.
sarvajanikPostJune 21, 2018, 04:14
Thanks for replying.
I do not see any UD Text defined for these tracks—as shown below. So I enabled Verbose log raw data from the Audio section of the Preferences—not the General (i'm assuming that was the one). It is quite small so am embedding it here. Thanks for your time.
File = /Volumes/Macintosh HD/Users/Sarvajanik/Music/Music Library/01 Standard Music/International Soundtracks/Coco (2017)/Disc 1 - English Version/01-01 Remember Me (Ernesto De la Cruz) - Robert Lopez, Kristen Anderson-Lopez feat. Benjamin Bratt.aiff
Raw Data:
File size: 22579648
Number of channels: 2
Sample size: 16 bit
Sample rate: 44100 Hz
Duration: 109280 ms
Bit rate: 1411 kbits/sec
ID3 Tag version 2.4.0
Tag at offset: 19277054 size = 3302594
Padding: 2019 bytes
00000010 00000053 00000043 (0000T3) TIT2
19277064: 54 49 54 32 00 00 00 21 00 00 03 52 65 6d 65 6d 62 65 72 20  |TIT2...!...Remember |
19277084: 4d 65 20 28 45 72 6e 65 73 74 6f 20 44 65 20 6c 61 20 43 72  |Me (Ernesto De la Cr|
19277104: 75 7a 29                                                     |uz)                 |
00000053 00000121 00000068 (0000T3) TPE1
19277107: 54 50 45 31 00 00 00 3a 00 00 03 52 6f 62 65 72 74 20 4c 6f  |TPE1...:...Robert Lo|
19277127: 70 65 7a 2c 20 4b 72 69 73 74 65 6e 20 41 6e 64 65 72 73 6f  |pez, Kristen Anderso|
19277147: 6e 2d 4c 6f 70 65 7a 20 66 65 61 74 2e 20 42 65 6e 6a 61 6d  |n-Lopez feat. Benjam|
19277167: 69 6e 20 42 72 61 74 74                                      |in Bratt            |
00000121 00000200 00000079 (0000T3) TPE2
19277175: 54 50 45 32 00 00 00 45 00 00 03 47 65 72 6d 61 69 6e 65 20  |TPE2...E...Germaine |
19277195: 46 72 61 6e 63 6f 2c 20 41 64 72 69 61 6e 20 4d 6f 6c 69 6e  |Franco, Adrian Molin|
19277215: 61 2c 20 52 6f 62 65 72 74 20 4c 6f 70 65 7a 2c 20 4b 72 69  |a, Robert Lopez, Kri|
19277235: 73 74 65 6e 20 41 6e 64 65 72 73 6f 6e 2d 4c 6f 70 65 7a     |sten Anderson-Lopez |
00000200 00000215 00000015 (0000T3) TALB
19277254: 54 41 4c 42 00 00 00 05 00 00 03 43 6f 63 6f                 |TALB.......Coco     |
00000215 00000230 00000015 (0000T3) TRCK
19277269: 54 52 43 4b 00 00 00 05 00 00 03 31 2f 31 31                 |TRCK.......1/11     |
00000230 00000244 00000014 (0000T3) TPOS
19277284: 54 50 4f 53 00 00 00 04 00 00 03 31 2f 33                    |TPOS.......1/3      |
00000244 00000259 00000015 (0000T3) TDRC
19277298: 54 44 52 43 00 00 00 05 00 00 03 32 30 31 37                 |TDRC.......2017     |
00000259 00000285 00000026 (0000T3) TIT1
19277313: 54 49 54 31 00 00 00 10 00 00 03 45 6e 67 6c 69 73 68 20 56  |TIT1.......English V|
19277333: 65 72 73 69 6f 6e                                            |ersion              |
00000285 00000332 00000047 (0000T3) TCOM
19277339: 54 43 4f 4d 00 00 00 25 00 00 03 52 6f 62 65 72 74 20 4c 6f  |TCOM...%...Robert Lo|
19277359: 70 65 7a 2c 20 4b 72 69 73 74 65 6e 20 41 6e 64 65 72 73 6f  |pez, Kristen Anderso|
19277379: 6e 2d 4c 6f 70 65 7a                                         |n-Lopez             |
00000332 00000353 00000021 (0000T3) TCON
19277386: 54 43 4f 4e 00 00 00 0b 00 00 03 53 6f 75 6e 64 74 72 61 63  |TCON.......Soundtrac|
19277406: 6b                                                           |k                   |
00000353 00000365 00000012 (0000T3) TCMP
19277407: 54 43 4d 50 00 00 00 02 00 00 03 31                          |TCMP.......1        |
00000365 00000380 00000015 (0000T3) TSOA
19277419: 54 53 4f 41 00 00 00 05 00 00 03 43 6f 63 6f                 |TSOA.......Coco     |
00000380 00000396 00000016 (0000T3) TMED
19277434: 54 4d 45 44 00 00 00 06 00 00 03 4d 75 73 69 63              |TMED.......Music    |
00000396 00000411 00000015 (0000T3) TFLT
19277450: 54 46 4c 54 00 00 00 05 00 00 03 41 49 46 46                 |TFLT.......AIFF     |
00000411 00000441 00000030 (0000T3) TPUB
19277465: 54 50 55 42 00 00 00 14 00 00 03 57 61 6c 74 20 44 69 73 6e  |TPUB.......Walt Disn|
19277485: 65 79 20 52 65 63 6f 72 64 73                                |ey Records          |
00000441 00000459 00000018 (0000T3) TLAN
19277495: 54 4c 41 4e 00 00 00 08 00 00 03 45 6e 67 6c 69 73 68        |TLAN.......English  |
00000459 00000861 00000402 (0000T3) COMM iTunes_CDDB_1
19277513: 43 4f 4d 4d 00 00 03 08 00 00 03 65 6e 67 69 54 75 6e 65 73  |COMM.......engiTunes|
19277533: 5f 43 44 44 42 5f 31 00 36 42 31 41 34 38 33 35 2b 35 30 34  |_CDDB_1.6B1A4835+504|
19277553: 38 30 31 2b 35 33 2b 31 35 30 2b 38 33 34 36 2b 31 36 32 37  |801+53+150+8346+1627|
19277573: 35 2b 32 31 39 31 31 2b 33 30 33 32 36 2b 34 33 34 34 37 2b  |5+21911+30326+43447+|
19277593: 34 37 32 35 35 2b 35 32 34 39 31 2b 36 34 39 30 36 2b 37 30  |47255+52491+64906+70|
19277613: 34 32 39 2b 37 39 37 30 37 2b 39 32 30 34 31 2b 31 30 30 32  |429+79707+92041+1002|
19277633: 33 37 2b 31 30 38 31 36 36 2b 31 31 33 38 30 32 2b 31 32 32  |37+108166+113802+122|
19277653: 32 31 37 2b 31 32 36 30 31 30 2b 31 33 31 32 34 36 2b 31 34  |217+126010+131246+14|
19277673: 33 36 36 31 2b 31 34 39 31 38 35 2b 31 35 38 33 31 30 2b 31  |3661+149185+158310+1|
19277693: 37 30 35 35 39 2b 31 38 38 33 33 34 2b 32 30 31 36 30 31 2b  |70559+188334+201601+|
19277713: 32 31 34 39 34 34 2b 32 33 30 35 33 37 2b 32 34 32 38 33 33  |214944+230537+242833|
19277733: 2b 32 35 37 36 36 35 2b 32 36 33 39 36 33 2b 32 36 39 37 31  |+257665+263963+26971|
19277753: 37 2b 32 37 35 30 30 31 2b 32 38 36 38 34 35 2b 32 39 34 39  |7+275001+286845+2949|
19277773: 39 39 2b 33 30 37 33 33 38 2b 33 32 31 31 34 32 2b 33 32 36  |99+307338+321142+326|
19277793: 32 33 31 2b 33 33 34 31 32 32 2b 33 33 35 37 33 33 2b 33 34  |231+334122+335733+34|
19277813: 36 34 39 38 2b 33 35 30 37 33 36 2b 33 35 34 39 30 36 2b 33  |6498+350736+354906+3|
19277833: 36 36 33 39 30 2b 33 37 32 30 30 38 2b 33 39 33 33 36 37 2b  |66390+372008+393367+|
19277853: 34 30 34 30 32 34 2b 34 31 34 36 33 34 2b 34 32 38 34 33 30  |404024+414634+428430|
19277873: 2b 34 33 37 34 33 38 2b 34 34 35 34 36 32 2b 34 35 36 38 32  |+437438+445462+45682|
...22 bytes truncated
00000861 00000900 00000039 (0000T3) COMM iTunes_CDDB_TrackNumber
19277915: 43 4f 4d 4d 00 00 00 1d 00 00 03 65 6e 67 69 54 75 6e 65 73  |COMM.......engiTunes|
19277935: 5f 43 44 44 42 5f 54 72 61 63 6b 4e 75 6d 62 65 72 00 31     |_CDDB_TrackNumber.1 |
00000900 03300575 03299675 (0000T0) APIC
19277954: 41 50 49 43 01 49 32 51 00 00 00 69 6d 61 67 65 2f 6a 70 65  |APIC.I2Q...image/jpe|
19277974: 67 00 03 00 ff d8 ff e0 00 10 4a 46 49 46 00 01 01 01 00 48  |g.........JFIF.....H|
19277994: 00 48 00 00 ff db 00 43 00 01 01 01 01 01 01 01 01 01 01 01  |.H.....C............|
19278014: 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01  |....................|
19278034: 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01  |....................|
19278054: 01 01 01 01 01 01 01 01 01 01 01 01 01 ff db 00 43 01 01 01  |................C...|
19278074: 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01  |....................|
19278094: 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01  |....................|
19278114: 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01  |....................|
19278134: 01 01 ff c0 00 11 08 07 08 07 08 03 01 11 00 02 11 01 03 11  |....................|
19278154: 01 ff c4 00 1f 00 00 03 01 00 02 03 01 01 01 00 00 00 00 00  |....................|
19278174: 00 00 00 01 02 03 08 09 06 07 0a 04 05 0b ff c4 00 79 10 01  |.................y..|
19278194: 01 00 02 01 03 03 03 02 04 03 05 00 01 02 47 01 02 03 11 12  |..............G.....|
19278214: 04 05 21 06 13 22 00 07 31 08 32 09 23 41 51 14 42 61 15 52  |..!.."..1.2.#AQ.Ba.R|
19278234: 71 81 a1 16 33 91 f0 0a 62 b1 c1 d1 17 24 43 72 82 e1 f1 18  |q...3...b....$Cr....|
19278254: 38 53 19 25 26 27 34 36 37 63 76 77 92 b5 b6 35 39 73 74 83  |8S.%&'467cvw...59st.|
19278274: 94 b2 b3 b7 d3 28 44 46 54 57 64 78 a2 45 55 56 84 93 97 a6  |.....(DFTWdx.EUV....|
19278294: b4 c2 1a 29 47 65 67 87 95 a3 a4 c3 c6 d6 d2 d4 f2 ff c4 00  |...)Geg.............|
19278314: 1e 01 00 03 00 01 05 01 01 00 00 00 00 00 00 00 00 00 00 01  |....................|
...3299295 bytes truncated
2MR2PostJune 21, 2018, 06:34
Oops...they're not using UDTIs. They're storing the metadata as named Comments. You'll see the items on the Comments editing panel.
The action remains the same other than choosing Comments in the User Defined Fields statement:
Remove all Comments with prefix 'iTunes_CDDB_'
I'm glad you found the Verbose option even though I told you to look in the wrong place. I'm on a Mac now, not my phone, so the reply will be more reliable 🙂
sarvajanikPostJune 21, 2018, 23:28
'—how/where may I view this?
'—I've created a new Action as shown below. Is that the correct way?
Thank you once again—for your time and support.
sarvajanikPostJune 21, 2018, 23:44
I think I found it. I clicked on the Show Edit Panel Picker form the Window menu and picked on the Comments tab—it replaced the UD Text section in the edit pane with the Comments tab, where all the iTunes junk data is visible. Deleting it from here seems to be solving my issue.
But since I have so many tracks, do tell me if my defined action (in my previous reply) is correct though. I'd like to be able to use that technique on the remaining files of mine.
Cheers.
2MR2PostJune 22, 2018, 00:00
You can set any Edit Panel Preset button to a different panel by right clicking on the button. (Yate uses context menus pretty much everywhere). There is no need to use the Edit Panel Picker panel.....it works but does take additional screen space. If you can't see the panel you want in the context menu, look at the Others submenu.
You're action is not correct. You must use a User Defined Fields statement. See the attached image for the required options.
sarvajanikPostJune 22, 2018, 04:45
The above action you suggested works like a charm! Many many thanks. Your support has been amazing—and has made me appreciate your product even more. Thank you for all the great work.
