Calculate Sound Check in action?
skyfingerPostAugust 27, 2018, 16:02
October 7, 2015, 18:55
Normal topicCalculate Sound Check in action?
I've been playing with an action to calculate and set the ReplayGain values. In the GUI, there's the option to Automatically calculate Sound Check (enabled) and a separate Calculate Sound Check command.
However, in the Actions, I'm only seeing commands pertaining to ReplayGain and not Sound Check. Is there a way to calculate Sound Check via action?
2MR2PostAugust 27, 2018, 16:18
Normal topicRe: Calculate Sound Check in action?
Yep...it's simply a separate statement. It's called 'Sound Check', in the Files category. As with the UI it will only process tracks which have ReplayGain values saved.
skyfingerPostAugust 28, 2018, 16:05
Duh! I must have glossed over that several times. Which leads to a feature request, I suppose. It'd be swell to have a search field for Functions.
2MR2PostAugust 28, 2018, 17:05
Type Select is enabled in the Action Groups and Functions columns.
Select the All group, click anywhere in the Functions column. Typing S O U will highlight Sound Check.
