Searches not working
aronsonPostMarch 20, 2019, 21:34
March 20, 2019, 19:23
Closed topicRe: Searches not working
Thanks! Just noticed this started today.
2MR2PostMarch 21, 2019, 08:37
As of 2019-03-21 we have not received a reply from Discogs. We've reached out a 2nd time via an alternate method. Worst case we will release a workaround in a few days. We'd much prefer to have them fix the issue and to continue to handle the authentication as they have documented it.
galvoPostMarch 22, 2019, 05:42
March 22, 2019, 09:38
Quote from 2MR2 on March 21, 2019, 08:37
Same problem here.
Please fix this asap, I use Discogs tagging everyday 🙁
You could always swap the workaround fix with the official one later down the road.
Thank you.
2MR2PostMarch 22, 2019, 13:54
Discogs just announced that the issue has been fixed. This has been confirmed. 2019-03-22 1:52 EDT.
Those of you that downloaded the posted patch build can safely remove the discogstoken Debug code.
v4.6.1 will be released on Monday and no patch for this issue is required.
