Only renames first track (issue)
VerticalPostJuly 15, 2020, 03:31
November 1, 2019, 04:50
Normal topicOnly renames first track (issue)
After release 6, when rename it only renames track 01 you then need to do it a second time and hit ok for the "File Moved" error.
Hope it makes since.
2MR2PostJuly 15, 2020, 06:35
Normal topicRe: Only renames first track (issue)
How are you renaming ... in the UI or via an action?
Do you have all loaded files selected or only a subset of the files in an album?
Are you renaming the a folder as well as the files?
Can you send the rename template your are using (by exporting) or send us a screenshot. Send it to support@2manyrobots.com.
Once we have more info we will fix ASAP.
2MR2PostJuly 15, 2020, 07:24
I found one edge case where I was allowing the 'File Moved' message to slip through 🙁
v6.0.0.1 will be released this morning. If the patch doesn't fix your issue I'll need more information.
2MR2PostJuly 15, 2020, 08:03
v6.0.0.1 has been released. Please do a Yate>Check for Updates.
VerticalPostJuly 15, 2020, 10:27
Thank you,
1. rename in the UI
2. all files selected
3. also rename folder
After v6.0.0.1 I don't get the 'File Moved' message but it still only rename the the first track + folder, I need to hit rename again to get the hole album renamed.
Remember I had zero issues renaming before v6.0.0.0
Rename template: https://www.dropbox.com/s/atkuwu4gbgovlep/File%20%26%20Folder.plist?dl=0
2MR2PostJuly 15, 2020, 10:47
Rename templates were expanded in v6.0. I can duplicate the issue with your template.
Let me see what's causing it.
2MR2PostJuly 15, 2020, 13:49
v6.0.0.2 has been released and it works with your template. Sorry for the mess up.
VerticalPostJuly 15, 2020, 21:50
Thank you, works...
2MR2PostJuly 15, 2020, 22:37
v6.0.0.2 was released which fixed a related rename bug
