substituting Yates multi value limiter ";;;" with MusicBrainzs multivalue limiter?
pacoinmassPostOctober 15, 2020, 22:01
July 24, 2015, 01:03
Normal topicsubstituting Yates multi value limiter ";;;" with MusicBrainzs multivalue limiter?
I've started retagging a few albums using MuiscBrainz and have noticed that the multi value delimiter used by MusicBrainz is ",".
Is there a way to substitute Yate's default at the time of import? I can't find a menu option to "switch default delimiters" for example.
Otherwise it looks like I have to manually find fields with multi values and manually make the substitution.
Thx.
2MR2PostOctober 15, 2020, 22:05
Normal topicRe: substituting Yates multi value limiter ";;;" with MusicBrainzs multivalue limiter?
Preferences - MusicBrainz - Shared with AcoustID - Join Override
Specify ;;; as the override and it will all be automatic. 🙂
pacoinmassPostOctober 15, 2020, 22:47
I'm sorry however where do I specify ;;; as the override? I couldn't find a menu to do that.
2MR2PostOctober 15, 2020, 22:51
Please see the attached image.
pacoinmassPostOctober 16, 2020, 21:54
Thx.
