Yate reads ALAC files as Part of a Compilation
DiskutantPostApril 22, 2023, 12:55
August 19, 2018, 10:09
Normal topicYate reads ALAC files as Part of a Compilation
I use xACT to convert files from FLAC to ALAC
xACT Website: http://xact.scottcbrown.org
When I open those ALAC files in Yate the "Part of a Compilation" checkbox is set. But other software, including Apple Music, don't read the compilation flag as set.
I thought this is a bug in xACT, but the author can't replicate it, as every other software shows the compilation flag as not set. So is this a bug in Yate, or is there some flag set that other software doesn't read but Yate does?
2MR2PostApril 22, 2023, 13:36
Yate uses the MPEG-4 atom 'cpil' which is the standard boolean atom to represent Part of a Compilation in ALAC files.
I've just checked what xACT is doing and they're writing an ASCII '0' (48, 0x30) as the value. 'cpil' is a boolean field and should have a value of 0 or 1. As Yate has to do something with the atom, it treats all non zero values as true. Checking around I have found other taggers which do the same.
The value should be a binary 0 or 1.
DiskutantPostApril 24, 2023, 11:14
Thank you, so it's a bug in xACT. I informed the author about your finding.
But also, shouldn't a boolean default to false if there is no value, or as in this case, a wrong value?
2MR2PostApril 24, 2023, 11:39
Typically 0 is false and all other numeric values are true. When converting a number to a boolean value this is the way it works.
