Adding composers to list
SnowdogPostDecember 4, 2023, 07:26
Normal topicAdding composers to list
I think I may have ballsed-up my settings somehow.
Composers are not being automatically added to the composers list (& I recall switching that off for some reason).
So now I have composers that I'd like to be added to the composers list but I'm wondering how to make lighter work of that than adding them one by one.
I tried shift-selecting an entire box set & using the "add to list" command hoping that everything that's not already there might be added but that didn't work.
So before I go & start adding them one by one, is there a way to do this quickly?
2MR2PostDecember 4, 2023, 08:01
There are two ways to enable/disable the automatic adding to lists. The first is in Preferences-Lists. The second is via the function button to the left of the field via the Enable/Disable Auto-Saves menu item.
I've written a simple action to add the Composer field items of all selected files to the Composer list. It can be run stand-alone, from the Multi Field Editor or from the function button to the left of the Composer field:
https://2manyrobots.com/actions/Add-Composers-to-Preference-List.zip
BTW: Add to List didn't work as you had more than one file selected ... with different Composer fields.
2MR2PostDecember 4, 2023, 12:17
I've changed the list function button Add(2) and Remove items to work with multiple files. It's logical 🙂 It'll be in v6.18
SnowdogPostDecember 4, 2023, 13:16
Thanks! I'll give it a go.
It's very easy, when one is tagging as many classical albums & box sets as I seem to be, to forget to manually add each new composer as they occur. I can't remember why I switched off the auto add function. I think maybe I hadn't settled on some spellings (Rachmaninov/Rachmaninoff, the million ways to render Chopin's first name, etc.) & I was getting duplicates with different spellings.
Anyway, hopefully this will solve the problem.
SnowdogPostDecember 4, 2023, 13:23
So, did I misunderstand? I've selected all the files in the set & tried to run the action & I get this error.
(Note: Not all the files have a composer name in the composer field. Would that make a difference?)
2MR2PostDecember 4, 2023, 14:29
You have Title selected in the MFE. The action only supports the Composer field.
You can also directly run it from the Composer field's function button's menu:
Multi Field Editor Actions>Add Composers to Preference List
SnowdogPostDecember 4, 2023, 14:59
Perfect!
SnowdogPostDecember 5, 2023, 19:34
That works a treat, thanks!
