Move & rename image file
SnowdogPostMarch 15, 2024, 16:50
Normal topicMove & rename image file
Okay, here's an interesting one.
It's so similar to other actions you've written for me, but I've double checked & I can't see one that'll do this particular thing.
As you can see from the screenshot, I have a 117 disc box set. In each numbered folder is a numbered sub folder "Scans, etc. XXX" & in there is a "back" & "Cover" image.
What I need to do is to move the "Cover" image up a level & add "Disc_XXX_"
Where the XXX is the disc number.
Everything is already padded to 3 digits.
I'd say "is that do-able" but I've learned everything id do-able.
I suppose the question is "have I explained that clearly enough"?
2MR2PostMarch 15, 2024, 17:04
pretty much.
Nope 🙂
As an example the folder ending in _117 contains a folder named Scans, etc. 117 which contains Cover.jpg.
Cover.jpg gets moved (copied?) up a level. So far so good. What does Disc_117_ get added to? Disc_117_Cover.jpg or something else?
SnowdogPostMarch 15, 2024, 17:23
Ah, yes... So moved up one level, no need to copy, I don't think.
"Disc_117_Cover.jpg" is correct, so that each cover image sits with the audio files & has the name number as the disc number.
So the result would look like the attached & all that would be left in the Scans folder is the back cover image.
Any clearer?
2MR2PostMarch 15, 2024, 17:43
got it :). Coming up shortly
2MR2PostMarch 15, 2024, 18:30
Download the action at:
https://2manyrobots.com/actions/Scans,-etc.-Move-Cover.zip
The action is named: Scans, etc. Move Cover.jpg
Everything is case sensitive and specified spaces are required: Scans,{space}etc.{space}# and Cover.jpg
# can contain any number of digits.
No error messages are issued. The constraints are met, or not.
2MR2PostMarch 15, 2024, 18:32
BTW: you must select the folder containing the ..._# folders as the root.
SnowdogPostMarch 15, 2024, 20:16
Amazing! Worked perfectly. 🙂
