Move all files up & delete empty folder
SnowdogPostJune 11, 2024, 12:54
Normal topicMove all files up & delete empty folder
I have an action called "Move audio files up one folder & delete empty folder" which does exactly what it says on the tin.
Could it be modified to move all the files in a folder up one folder & delete empty folder?
I'm getting a lot of stuff sent to me where every folder has a completely unnecessary sub-folder with everything in it. Audio, PDFs, image files etc. & it would be nice to dispose of the sub-folders completely as a first step in one move.
Thanks. 🙂
2MR2PostJune 11, 2024, 13:06
Yep this can be done in a single statement. However, I've a lot of actions archived (somewhere) for you and I can't find this one.
Open the Action Manager (Actions menu).
Select the Move audio files up one folder & delete empty folder action and from the context menu (right click) select Export.
On the displayed panel simply hit Export.
On the standard save-as panel, save the file somewhere. Please make sure Export as zip file is checked.
Email me the file to support@2manyrobots.com and I'll modify it.
SnowdogPostJune 11, 2024, 15:24
Okay, that's done. 🙂
2MR2PostJune 11, 2024, 15:52
That really was a one liner. Now it's a two liner. 🙂
Download:
https://2manyrobots.com/actions/Move-Audio-(and-Non-Audio)-Files-Up-One-Folder-&-Delete-Empty-Folder.zip
The action is called: Move Audio (and Non Audio) Files Up One Folder & Delete Empty Folder
It will move all contained non audio files and contained folders with the audio files. Note it will not overwrite existing files and a contained folder which itself contains other audio files will not be moved.
SnowdogPostJune 12, 2024, 05:06
Excellent, thanks! 🙂
