Replicating my Yate on a second machine.
SnowdogPostOctober 22, 2025, 18:41
Normal topicReplicating my Yate on a second machine.
Okay, this is causing me issues again.
Having been working fine for a while using the Dropbox method, today I quit Yate A (& it saved the updated settings to the specified location).
I launched Yate B & it gave me an error message about importing the settings. (I think this may have been a problem with the aforementioned Dropbox, as it's busy syncing a lot of stuff, which is my bad.)
The problem with this is that I cannot then quit Yate B without it saving its own older version of the settings back to the specified location. Then, when I launch Yate A again, it imports the old settings. Fortunately, that last action you wrote for me is still in the trash, so I was able to re-install it.
I then figured, well why don't I put the shared prefs file into a shared folder that isn't used by Dropbox!
So, for the very purpose of this sort of thing, I happen to have the Public > Drop Box folder set up so that I can see it on the other Mac.
So I told Yate A to save the file there (screenshot 1) but when I quit I get an error message (screenshot 2)
Any idea why it won't save the file to the specified location? Is it a user privileges thing, maybe?
EDIT: I tried updating the privileges on the folder & it didn't help.
EDIT 2: I just noticed, upon launching Yate B that its error message seemed to be about different version of the app, so I probably should actually read error messages in future rather than jumping the gun & assuming I know what they're about. 🙄
Be that as it may, I'm still curious as to why my non-Dropbox solution isn't working.
2MR2PostOctober 22, 2025, 21:07
The root of this problem is that the Dropbox ability to quickly sync is frail.
I've had similar issues many times over the years. A couple of points:
Yate maintains 10 (by default) backups of your settings. They can be quickly imported via Yate>Import Settings from Backup
If you start or close Yate with the Shift key held, the sync file is not loaded or saved. When you get an error loading the sync settings when starting Yate, close the app holding the Shift key. Wait a few seconds and try again. In my experience this always works.
The 'An error occurred in the destination for the data' is the extracted Mac error message. Not much to go on there. In system settings make sure that Yate has Full Disk Access. Also make sure that Yate is listed in Files & Folders. You'll have to search for these settings as their location in System Settings is OS version dependent.
Aside from using the Shift key (which you should remember), I also tend to write an out of bounds (oob) copy of the settings whenever I make a change which is critical to preserve. Essentially I manually export the settings to a known location. That way if DB messes up and I don't catch the fact,I know that the oob settings are available. I do it via an action. I have the path hardcoded in my action.
Basically create a one line action which is an Application Settings Management statement. There are only two settings in the statement. The top control must be: Export Application Settings. The text field contains the full path to the file to be written. If you select the text field, you can drag in the folder then add the filename. It must have a .plist or .zip filename extension. This is equivalent to doing a Yate>Export Settings ... but it's much faster as you don't have to select the file's location.
SnowdogPostOctober 23, 2025, 03:17
That's amazing, thanks.
Yate has full disk access & is listed in "Files & Folders" so I'm not sure what the issue is.
I may go back to the Dropbox method, now that I have the extra info.
