Playlist
DJunpridictabullPostApril 15, 2025, 22:06
Normal topicPlaylist
I would like to create customized playlists that can be stored in a specific folder of my choosing. These playlists can either reflect the album name or feature a unique title that I create, instead of simply using the location of the MP3 files.
2MR2PostApril 16, 2025, 09:46
Well theres not much here to go on 🙂
I'm assuming that you do not mean m3u files? Do you mean an arbitrary text file? If so, what do you want to be stored for each file?
If this is for a per file value? What do you want to use for the text? Where would the per file title come from? Will you be saving it to a UDTI or custom field in the tracks?
2MR2PostApril 16, 2025, 10:25
I've thought on this a little more. I could write an action which takes a rename template. The action would produce a text file where each line represents the filename produced by the rename template (without the filename extension).
This would allow you to easily specify whatever you'd like to appear on each text line.
For example:
❨Album❩ - ❨Title❩
Does this make sense?
DJunpridictabullPostApril 17, 2025, 20:41
Yes, it does make sense, and that is what I was trying to say. Thank you
2MR2PostApril 21, 2025, 16:52
Generic Text Exporter action. V8.1.1 of Yate required
