How to log information when an action is run?
Gary-SwiftPostJune 2, 2025, 04:44
April 29, 2014, 06:12
Normal topicHow to log information when an action is run?
This is intended to be be used for debugging.
Sometimes I create action that does not work as intended.
Can I add log statements at various points in the flow control so that I see see the log outputs as the action runs?
2MR2PostJune 2, 2025, 07:15
There is the Debug statement and breakpoints. Once either it encountered, you can view all variables and most fields.
The Prompt statement can also log data to the system console (not recommended as the messages are not trivial to extract). The Prompt statemnent can also be used to log data to a file of your choosing pr a default location. While logging is useful, I fund the Debug/breakpoint methods easier to get quick results.
Use Help>Search Yate Help and search for Debugging Actions.
The logging is described in the help for the Prompt statement.
Gary-SwiftPostJune 2, 2025, 15:30
Nice. Prompt > 'Show in Log Viewer' is what I was looking for. Thank you.
