Classical Field - FLAC Tag Question(s)
acuneoPostJuly 29, 2025, 14:25
September 9, 2020, 18:30
Normal topicClassical Field - FLAC Tag Question(s)
I am struggling trying to add fields for classical Work and Movement to my local library. I intend to populate them by hand as needed in the Yate File List Area of the Main Window. I have run into an inconsistency that makes me wonder if I am still not understanding.
In Yate Help, the Yate Tag Mapping Table shows a field 'Work Name' mapping to Vorbis 'WORK--NAME'. in Settings>FLAC/OGG the field 'Work Name' maps to the FLAC/OGG tag 'WORK'. Are these in conflict? What should the correct tag be?
The File List Header has columns 'Work Name' and 'Movement Name' which I expect from both help and settings.
In the edit panel there is a UDText item (solid black circle) 'MVN' and a text value that I typed in sometime over the last two days. The text value looks like a movement name. But not the movement name I see in the file list header. Can I remove these MVN entries?
My media server (MinimServer) recognizes indices for 'Work' and 'Movement' which I think should be Yate fields but the fields are 'Work Name' and 'Movement Name'.
I'd appreciate any thing you can tell me to point me in the right direction.
Regards,
Art Cuneo
2MR2PostJuly 29, 2025, 15:11
The built in Apple classical fields are separate from the classical fields used by various other players. This is done as some users populate their files into Apple and other players. Typically the non Apple fields used are Work and Part but a full list of MusicBrainz classical fields is: Cardinal Number, Classical Catalog, Opus, Part and Work. This can be confusing as there are so many classical implementations for different players.
If you're only using FLAC files you can simply remap the Work Name and Movement Name fields to whatever MinimServer requires. (Work and Movement?). If you want to do it this way go to Settings - FLAC/OGG Mappings and edit the mappings for Work Name and Movement Name. If you do it this way you can use the built in fields. ie. change MOVEMENT--NAME to MOVEMENT and WORK--NAME to WORK. Work Name and Movement Name will now map to whatever you set. This might be the easiest way for you to go. Remember that when you change the mappings, whatever you set before will not appear in the fields. They're not mapped elsewhere and will show up on the UD Text editing panel.
Alternately you can create separate fields to represent Work and Movement. Yate has lots of functionality which uses and fills the MusicBrainz classical tags. You can assign the custom fields and an editing panel to display them by importing a single edit panel. On Yate's web resources page go to the Templates section and look for: MusicBrainz Classical Editing Panel and Custom Fields.
Download the file and import the zip file via Yate>Import Settings. Follow the instructions. Once installed you can display the MB Classical edit panel as you would any other edit panel. This edit panel contains the Apple and MusicBrainz fields. More than likely what you want is Work and Part which is also used, for example, by Roon. My understanding is that MinimServer allows you to alias fields. In this case you would Alias Part to Movement. Alternately you can change the mapping for the Part custom field in Settings - General - Custom Fields to reflect MOVEMENT in FLAC files as opposed to Part.
There is no reason for you to use the MB Classical edit panel as you can place the fields on whatever custom edit panel you wish. For example there is a Roon custom edit panel which also contains these fields.
If Movement ends up differing from Part, you can always create a custom field named Movement which has the desired mapping. This field can then be placed on an edit panel.
Basically all of the above simply creates custom fields and places them on a panel to provide easy editing. (It's easier than editing them on the All Tags edit panel). The custom fields, once defined, can be displayed as columns in the main window. What this means is that if you wish you can manually create custom fields named Work and Movement , mapped to whatever you wish, and place them wherever you wish. The advantage to having the MusicBrainz custom fields is if you're going to import metadata from MusicBrainz. Use these fields as opposed to the built in Apple custom fields.
2MR2PostJuly 29, 2025, 16:04
Based on a 2024 post by the MinimServer author, the basic default tags are: Album, AlbumArtist, Artist, Composer, Date, DiscNumber, DiscSubtitle, Genre, Group, Title, TrackNumber. Work and Movement are not mentioned but are easy to create.
If you wish I can create an edit panel for you which displays the typical MinimServer tags. Let me know
2MR2PostJuly 29, 2025, 20:19
Hi, I just reread your initial post. (I'm working off a 7 hour time zone change and I'm a little fuzzy 🙂
Settings-FLAC/OGG should have a mapping of Work Name to WORK--NAME ... out of the box. Are you sure about the mapping in settings? Unless you've intentionally changed the mappings you can do a Yate>Reset Built in Items>Reset FLAC/OGG Mappings to get back to the correct defaults.
These are the Apple fields. The FLAC mappings will need editing in order to work with MinimServer.
You can remove the MVN items from the All Tags or UD Text editing panels. It can also be done by a one line action. Set User Defined Text Item with a destination of MVN and an empty source.
MinimServer uses internal mappings of Work and Movement. Yate uses internal names Work Name and Movement Name. (These are the Apple names). Both Yate and MinimServer have to be aligned with the actual low level mappings.
The alignment can happen by making mapping changes in Yate or by defining aliasTags in MinimServer. ie. change Yate's defaults or configure MinimServer. As MinimServer does the work for you with ID3 and MPEG-4 files, all you have to do is change the mappings in Yate for FLAC files.
I don't know which of the Work and Movement tags (whatever they're called) you currently have in use in your files. If you're just starting to populate the tags, it makes it is easier as your don't have to worry about carrying over pre-MinimServer values. If you're tagging classical files you'll probably also need a Group tag in MinimServer which was introduced the same time as Work. This can be mapped to the standard Grouping tag or can be something else entirely. I'd make a new field as MinimServer's interpretation of Group differs from a standard Grouping tag.
I'll document my recommended mapping changes tomorrow. The list is not that long. Hopefully I'll be a little less fuzzy tomorrow.
2MR2PostJuly 30, 2025, 09:48
Here's the steps to get your classical tags working for MinimServer:
Go to Settings-FLACC/OGG Mappings
If Work Name is mapped to WORK, something has been changed. You can either set it to something else or do a Yate>Reset Built in Items>Reset FLAC/OGG Settings. Work Name cannot be mapped to WORK or the next steps will not work.
Change the mapping for Movement Number to be MOVEMENTNUMBER. If there is still a mapping of Movement Number to MOVEMENT, delete it.
Change the Movement Name mapping to be MOVEMENT.
If either of the changed items have more than one mapping, MOVEMENTNUMBER and MOVEMENT must be the first (preceded by a -). See the screenshot. The secondary mappings are read only and are not important.
Download https://2manyrobots.com/actions/MinimServer-Edit-Panel.zip
Drag the zip file to the main window's file list area. Follow the instructions to install two custom fields and an edt panel named MinimServer.
Work and Group are custom fields which work with the same named MinimServer items.
The panel uses the standard Movement fields. While Movement is displayed as the field name it is associated with the Movement Name column. Work and Group will have available columns.
There's lots of room to add additional items to the panel if you wish.
Sorry for all the fuzzy ramblings yesterday
acuneoPostJuly 30, 2025, 18:10
Thanks for all your comments yesterday and for today's compilation and link/download. It seems like it should doable for me.
I reset the FLAC/OGG Mappings. Field 'Work Name' now points to the correct Name. I made the other mapping changes. I deleted the duplicate 'Movement Name' and 'Movement Number' mappings and removed the '-' prefix. What I have is 'Movement Name' ... 'MOVEMENT' and 'Movement Number' ... 'MOVEMENTNUMBER'. I think/hope that is correct. The panel and custom fields seem to have installed without issue. I will make my Work/Movement changes to the CD flac files that I have been testing with and give it a go. I'm cautiously optimistic.
Thanks again for the responses.
acuneoPostJuly 31, 2025, 10:48
Just a courtesy update: This didn't work for me. I got thrown off by the concept of secondary mappings and the '-' prefix. I tried to remove the additional mappings without really understanding what I was doing. Ended up reinstalling Yate to get a clean baseline.
2MR2PostJuly 31, 2025, 10:53
Hmm. Tag aliases in MinimServer can do the trick. However according to their documentation UDTI names which match their internal names always take priority. ie. the Movement changes should have worked. Group and Work as well.
acuneoPostAugust 4, 2025, 12:08
A positive update. Classical work and movement tag values are working from Yate to MinimServer to my 2 UPNP control points now. The tag fields (names) are WORK--NAME and MOVEMENTNAME. I added those tag names to MinimServer property indexTags. Not especially pretty but they work. I will fill in the values for particular files as needed for my favorite works and performances. I am very happy to be able to use all Yate's editing modes to manage this information. I'm particular about metadata and not happy with public sources like Discogs or Musicbrainz.
I should leave well enough alone but I'm going to see if I can get tag fields 'Work' and 'Movement Name' to work in Yate. Thanks for your time and help.
2MR2PostAugust 4, 2025, 12:17
Thanks for the update. According to the MinimServer documentation, anything which directly maps to their internal names should work. The preset for custom field Work should be interpreted correctly.
Mingle Forum by Cartpauj | Version: 1.1.0beta | Page loaded in: 0.025 seconds.
