Removing numbers from Title
DJunpridictabullPostMarch 31, 2026, 16:38
Normal topicRemoving numbers from Title
Good afternoon,
I hope you’re doing well. I had a quick question and was hoping you could assist me.
I am looking to clean up a list of track titles and Artist by removing any numbers that appear at the beginning and end of the Artist or titles.
For example:
Before:
Billy Idol – White Wedding Parts 1 & 2 (Shotgun Mix) 147
17. ABBA – The Name of the Game 154
10 - Fair Control - Symphony Of Love 98
04 B B & Q Band - On The Beat 119
After:
Is there an efficient method or tool you would recommend to accomplish this?
Thank you in advance for your time and assistance.
2MR2PostMarch 31, 2026, 21:06
Download the action at :
https://2manyrobots.com/actions/Remove-leading-and-trailing-Numbers-from-Title.zip
It seems to work on your examples. Let me know.
2MR2PostMarch 31, 2026, 21:12
Oops I only did Title. This one will do Artist as well.
https://2manyrobots.com/actions/Remove-leading-and-trailing-Numbers-from-Title-and-Artist.zip
DJunpridictabullPostMarch 31, 2026, 22:56
Thank you, but I'm unable to install due to I'm running version 8.3.6. (Yate 8.3.6 is currently the newest version available.) and the File /Users/DJunpridictabull/Documents/Remove-leading-and-trailing-Numbers-from-Title-and-Artist.plist was created by version 9.0 build 12642(12478) of Yate which is newer than the current version 8.3.6 build 12477(12477).
2MR2PostMarch 31, 2026, 23:10
Sorry about that. I'm testing v9.0 (coming soon) and I forgot to mark the action for 8.3.6. I've uploaded the modified zip file to the same location and cleared my cache.
Download it again from the same location. Make sure that you have v1.1 of the action after downloading. Some browsers may cache the older download. You can verify that you have the correct download by dropping the zip file in the main window's file list area while holding down the Shift key.
DJunpridictabullPostMarch 31, 2026, 23:26
Thank you it works
