Have control over the number of panels visible
cpkPostMarch 1, 2015, 07:00
March 1, 2015, 02:55
Normal topicHave control over the number of panels visible
Currently, I have ten panel "buttons" at any given time. I can change them and create several panel sets but no matter how much I resize the window and the panel buttons get bigger and bigger I can't have more than ten. This is kind of a pain since I have to frequently change the saved set as I am working though my files when it is much faster to just click once a panel button.
I have a 27" iMac and I could easily have 14 buttons (7 in 2 rows) or even 21 if they were in 3 rows (though I personally don't need that many panels and would need even fewer if I could edit the existing ones (but that is another request).
2MR2PostMarch 1, 2015, 07:09
Normal topicRe: Have control over the number of panels visible
Another somewhat major change. I'll look into customizing the number of 'rows' of displayable buttons.
cpkPostMarch 1, 2015, 17:41
Looking at this now I should have said "panel buttons visible" in the title but I think that was clear from my description. I was hoping it wouldn't be major to add the ability to add more panel buttons. Adding more rows would certainly do the trick - I hope it isn't a difficult request. Thank you for at least considering it.
koehntoppPostJuly 12, 2026, 13:37
July 12, 2026, 17:24
Quote from 2MR2 on March 1, 2015, 07:09
Let me give a +1 to this. I could really do with two or three additional lines.
2MR2PostJuly 12, 2026, 14:16
This is in response to a really old post.
You want more than 10 edit panel buttons at a time? One of the major requests I have is to display less. Yate v10.0 will have the ability to change the edit panel button layout. Currently this is one row of 2 - 10 buttons or two rows of 2 - 5 buttons. Saved layouts automatically retain the number of buttons and rows.
I could probably change it relatively simply to allow 2 rows of 10 buttons. Allowing more than two rows is problematic as I have issues when the window is dropped to its minimum size.
See the image which displays one row of 10.
2MR2PostJuly 12, 2026, 16:48
Ok .... Yate v10.0 will suport up to 2 rows of 10 buttons. I can't see the need for more than 20. I had a hard time filling 20 while testing 🙂
koehntoppPostSeptember 2, 2026, 02:19
THANK YOU - *much* better already.
I can live with 10 (although I could probably use some more...), but that's still less than half of the vertical space.
I'd love to have the album art below, but that would need another 4 rows ...
2MR2PostSeptember 2, 2026, 08:41
When creating or editing a custom panel, it can be resized vertically adding available rows. The number of available rows is determined by the display size. The initial number of rows reflects the size of the built in edit panels.
