misfunction in "Compare Text Test"
not.relevantPostMay 3, 2015, 09:18
May 2, 2015, 07:55
Normal topicmisfunction in "Compare Text Test"
It took me some time to "debug" the problem:
The function "Compare Text Test" setting "Ends with" and a Text shows the same result as "contains".
Example:
String: AnyName!OfBand --> with the setting "Ends with" Text='!' should be false but is true
String: AnyName!OfBand --> with the setting "contains" Text='!' is true
Can anybody verify this?
n.r.
2MR2PostMay 3, 2015, 09:31
Normal topicRe: misfunction in "Compare Text Test"
Verified. Ends With and Starts With at some point broke due to a type and end up being Contains.
Patch ASAP.
2MR2PostMay 3, 2015, 09:52
v3.6.0.2 released. Do a Yate>Check for updates to manually load it.
I must have hit a key while looking at the code and the typo unfortunately did not cause a compile error.....and Xcode autosaves files 🙁
not.relevantPostMay 3, 2015, 11:03
May 2, 2015, 07:55
WOW - that was quick.
I wish some other companies would fix there products that fast (-;
Thanks a lot - that saves me some time ....
