Yate keeps crashing
wj.dronkersPostSeptember 19, 2015, 16:41
September 19, 2015, 20:37
Normal topicYate keeps crashing
Process: Yate [1396]
Path: /Applications/Yate.app/Contents/MacOS/Yate
Identifier: com.2manyrobots.Yate
Version: ???
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Yate [1396]
User ID: 501
Date/Time: 2015-09-19 22:35:59.207 +0200
OS Version: Mac OS X 10.10.5 (14F27)
Report Version: 11
Anonymous UUID: C68FABFE-DB8C-182D-A478-68A69174A089
Sleep/Wake UUID: D3FD0442-A424-4BA1-9620-1F633F666773
Time Awake Since Boot: 72000 seconds
Time Since Wake: 5900 seconds
Crashed Thread: 0
Exception Type: EXC_CRASH (Code Signature Invalid)
Exception Codes: 0x0000000000000000, 0x0000000000000000
kernel messages:
VM Regions Near 0x7fff753bb0a0 (cr2):
__LINKEDIT 00007fff66dcf000-00007fff66de3000 [ 80K] r--/rwx SM=COW /usr/lib/dyld
--> Submap 00007fff70000000-00007fff80000000 [256.0M] r--/rwx SM=PRV process-only VM submap
unused shlib __DATA 00007fff74a84000-00007fff77084000 [ 38.0M] rw-/rw- SM=COW system shared lib __DATA not used by this process
Thread 0 Crashed:
0 dyld 0x00007fff66d60000 _dyld_start + 0
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x000000000000000d rbx: 0x0000000000000000 rcx: 0x0000000000000000 rdx: 0x0000000000000000
rdi: 0x0000000000000000 rsi: 0x0000000000000000 rbp: 0x0000000000000000 rsp: 0x00007fff5fbffcd8
r8: 0x0000000000000000 r9: 0x0000000000000000 r10: 0x0000000000000000 r11: 0x0000000000000000
r12: 0x0000000000000000 r13: 0x0000000000000000 r14: 0x0000000000000000 r15: 0x0000000000000000
rip: 0x00007fff66d60000 rfl: 0x0000000000000201 cr2: 0x00007fff753bb0a0
Logical CPU: 0
Error Code: 0x020000f4
Trap Number: 133
Binary Images:
0x7fff66d5f000 - 0x7fff66d95887 dyld (???) <B1B370A5-479F-3533-8AD7-97B687D4F989> /usr/lib/dyld
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 21413
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=300K resident=296K(99%) swapped_out_or_unallocated=4K(1%)
Writable regions: Total=8424K written=0K(0%) resident=12K(0%) swapped_out=0K(0%) unallocated=8412K(100%)
REGION TYPE VIRTUAL
STACK GUARD 56.0M
Stack 8192K
VM_ALLOCATE 8K
VM_ALLOCATE (reserved) 8K reserved VM address space (unallocated)
__DATA 228K
__LINKEDIT 80K
__TEXT 220K
mapped file 3768K
shared memory 4K
TOTAL 68.2M
TOTAL, minus reserved VM space 68.2M
2MR2PostSeptember 19, 2015, 17:48
Normal topicRe: Yate keeps crashing
It looks like your binary has been tampered with. There is no version for the binary and the exception is caused by an invalid code signature. I suggest deleting the copy you are attempting to run and that you download a clean copy from our web site.
I've just downloaded the version from the site and it is fine.
2MR2PostSeptember 19, 2015, 20:04
I've found more information on the Code Signature Invalid message. It typically means that an application designed to be distributed in the Mac App Store which has entitlements is incorrectly signed. Yate has no entitlements, is not designed to be run in the Mac App Store and is signed exactly as Apple says it should be. I'm assuming in the Mac System Preferences - Security & Privacy section you have "Mac App Store & Identified Developers" set. However, even an incorrect setting here should not result in the crash. I still think it is the binary as nobody else has reported this issue.
