Swapping Meta Data Between Files
noforkerPostFebruary 8, 2017, 19:51
July 25, 2016, 01:03
Normal topicSwapping Meta Data Between Files
Hello! What would be the best method to swap all meta data between two files?
2MR2PostFebruary 8, 2017, 20:12
Normal topicRe: Swapping Meta Data Between Files
Hmm.... swap or copy?
1) If you want to copy metadata from one file to another.
- Set the Yate Open Mode to Playlist.
- drag over the two files involved in the copy.
- depending on the order of the files do an Actions>Copy Metadata>Top to Bottom or Actions>Copy Metadata Bottom to Top
2) If you want to copy the metadata from one rip of an album to a newer better rip (very common):
- Set the Open Mode (File menu) to Album if each release is in its own folder, or for finer control to Playlist
- Set the Open Mode to "Add to the File List"
- drag over the first album
- drag over the second
- if necessary drag and drop the tracks so that one album is entirely at the top.
- ensure the tracks in each album are ordered the same.
- do the appropriate Actions>Copy Metadata>.... function
3) If you really want to swap the metadata between two tracks:
- on File-1 do a File>Export (with all metadata selected when prompted)
- on File-2 do a File>Export (with all metadata selected when prompted)
- on File-1 do a File>Import (with all metadata selected) on File-2's export
- on File-2 do a File>Import (with all metadata selected) on File-1's export
.... and this can all be done via actions 🙂
noforkerPostFebruary 8, 2017, 22:35
Swap. Export and Import worked perfectly. Thank you!
