Yate Load Error // Save Error
breezy_weezyPostMarch 18, 2017, 16:41
December 20, 2016, 20:27
Normal topicYate Load Error // Save Error
I am using ExpanDrive - http://www.expandrive.com/ - to mount my Dropbox as a network drive and am running into some problems.
It seems to be hit or miss trying to load a folder of files into Yate. Sometimes it will load some, but never will it load all and not without errors of some sort. The two that I keep getting when trying to save metadata & then rename the files are these.
1. Load Error - http://i.imgur.com/cQWlGq5.jpg
2. Save Error - http://i.imgur.com/mAVKGxX.jpg
Any ideas why I am getting these / how to fix or overcome them. I've also tried using Eltima Software's Cloud Mounter app (https://cloudmounter.net/) but the mounted volume doesn't show up in Yate. I can, however, drag-and-drop some files into Yate, but seem to get the exact same results as described above.
Thanks in advance!
Brian
2MR2PostMarch 18, 2017, 17:03
Normal topicRe: Yate Load Error // Save Error
I'd love to help, but unfortunately there s little I can do. Yate does not directly access files for reading or writing but rather goes through the OS for all file access. That's the only reason that external mounts and file systems provided by plugin support will work. In both images I can see that Yate got a read error, which implies that the OS got a read error while accessing the file and passed it up. Read errors can happen when saving, as a Save operation requires rereading a portion of the file after a write.
There are obviously some connectivity issues. Most operations such as Finder copies read the file in its entirety and it is possible that the driver favours streaming. Yate definitely accesses files by seeking around the file and only reading the necessary data. All of my files are on a NAS drive and there are no issues accessing them. This might be a driver implementation issue.
