test if albumartist and artist are different, if yes...
2manyFLACPostMarch 26, 2017, 06:54
September 20, 2015, 11:49
Normal topictest if albumartist and artist are different, if yes...
hi
i have been trying to write the action that would test if <Album Artist> and <Artist> fields are different, and if YES, then append the <Album Artist> to the <Title> field.
any tips on what I'm missing?
I've tried
Force Group Execution
Run action <compare the two fields>
If true
Run action <append>
Else
EndIf
2MR2PostMarch 26, 2017, 07:57
Normal topicRe: test if albumartist and artist are different, if yes...
I can't see the sub-actions being used, so I can't tell what is being done there. You could do the following:
Force Grouped Execution
Test if the Artist field is not equal to "\[Album Artist]" (Set result)
Append "…-…" and the Album Artist field to the Title field
Please view the above in the forum as the mailer strips out backslashes. The ... sequences are use to represent leading and trailing spaces and/or newline characters.
Yate allows you to insert the current and initial contents of any of its fields directly into most action statements. Rather than remember the exact field names and the cryptic escape sequences you can do the insertion from a field's context menu via Insert Yate Field.
If for some reason, and there are may valid reasons, why you want your main action to run stepwise you can always do the work above in an inline action:
Run inline action 'Compare and Possibly Append' grouped
Start Compare and Possibly Append
2manyFLACPostMarch 26, 2017, 10:51
thank you, i got it working with your help!
much appreciated. i was overthinking it with sub actions.
