Rename error
HenioPostDecember 10, 2018, 14:03
October 25, 2018, 16:34
Normal topicRename error
Files are on NFS disk with "rw" access.
OS is OSX El Capitan (10.11.6)
Yate Version 4.4 (7666.7645)
When I change any metadata and save file everything is OK.
When I rename file error occure:
"Rename Error
Error resetting modification date after renaming of file:
/Volumes/Music/New/Moanaa/Passage/Moanaa - Passage - 06 The Shift.m4a
to
/Volumes/Music/New/Moanaa/Passage/Moanaa - Passage - 06 - The Shift.m4a
You don’t have permission."
After press "Cancel" or "Continue" filename is changed as I expected.
I try check or uncheck "Preserve modification date/time when saving audio files" option. Nothing change.
Is any method to disable "Rename Error" window?
Regards,
Henio
2MR2PostDecember 10, 2018, 14:40
Normal topicRe: Rename error
Hmm...it seems as if my reply was lost.
The NFS driver is returning the 'You don’t have permission' portion of the error message. I can add something to disable the error messages but there are ramifications. If the error occurs and I do not post the message, every time you rename a file the driver may have modified the timestamp. This can occur when renaming a file or folder. Further, I would bet that 'Preserve modification date/time when saving audio files' will never work.
I'll reach out to you directly with a patch to test.
HenioPostDecember 10, 2018, 16:29
Thank You!!!
Working as expected.
It is extremely high level of support.
