Math/Counter
LouisMackey111PostDecember 14, 2018, 17:25
November 8, 2014, 19:45
Normal topicMath/Counter
I want to count the number of times I go thru a section of code what can I used as a counter?
2MR2PostDecember 14, 2018, 17:37
Normal topicRe: Math/Counter
Variables and Named Variables can be used on any of the numeric statements:
Increment named variable 'Counter'
Named Variables are created when first set and are empty, or 0, until created. The above Increment statement will create the Named Variable if it does not exist. So the first Increment will set it to 1.
You can use a Compare Numeric Test statement to test the value.
Test if the numeric value of named variable 'Counter' > "5" (Set result)
LouisMackey111PostDecember 15, 2018, 14:17
Thats got it.
Thanks.
Mingle Forum by Cartpauj | Version: 1.1.0beta | Page loaded in: 0.058 seconds.
