How do I batch change numbering of tracks.
MatthewLPostApril 16, 2019, 17:58
April 16, 2019, 21:38
Normal topicHow do I batch change numbering of tracks.
Apologies - this seems a terribly simple question, but I cannot see how this is done. I have previously used Tag & Rename to do this, and now am just getting familiar with Yate.
Problem: 1 album with 2 discs of 22 & 17 tracks. Currently mislabelled as
Tracks 1-22 of 22; Disc 1 of 2
Tracks 23 - 39 of 17; Disc 2 of 2.
I want to change 23 to 39 to 1 to 17 in Disc 2, e.g. put in 1 as the starting integer, then add +1 for each next track. How do I do this without manually editing every individual track?
2MR2PostApril 16, 2019, 18:09
Normal topicRe: How do I batch change numbering of tracks.
In Yate terminology....this is not Batch Processing 🙂
If the Disk field is set correctly you can load the entire album and do an Actions>Renumber Tracks>Per Disc
If the disk field is not set, load only the tracks from Disc 2 and do an Actions>Renumber Tracks>From...1. From... 1 will work regardless of the consistency of the Album and Disc fields.
Try it. No Renumber will automatically save the files.
MatthewLPostApril 17, 2019, 15:51
Thanks, that is exactly what I wanted.
Thanks for your help
