Drag and drop Artwork in info tab
angangPostAugust 28, 2013, 01:05
August 23, 2013, 03:38
Normal topicDrag and drop Artwork in info tab
Hello,
It should be great to have directly access to at least cover front field because of the need to change from info tab to artwork tab just to drag the cover.
Also il should be great to detach each tab to have a floating window just like the "editor' window.
thank you for your interest
Regards
2MR2PostAugust 28, 2013, 06:13
Normal topicRe: Drag and drop Artwork in info tab
Currently, while running an action and the Pending Action window is displayed, we allow you to drag artwork to the main list of files. This means you don't have to change to the artwork tab. I'll take a look at allowing this all the time. I'll also look into allowing the drag out/save functionality to the potentially displayed thumbnail on the Info tab.
Floating tabs is an interesting idea. I'll add it to the list. Currently I'm deep in v2.4 which has quite an extensive list of new features.
angangPostAugust 28, 2013, 09:43
ok, I look forward
