Auto define tracks
PaulPostFebruary 7, 2020, 07:13
February 7, 2020, 11:47
Normal topicAuto define tracks
Hi, I am new to Yate.... I read that it is possible to auto define tracks without Title & Artistname. As I have many Compilations from DJ friends it is quite a lot work to rename every track manually after converting the CDs. Is there a function like for example Shazam? Thank you for your help!
2MR2PostFebruary 7, 2020, 07:42
Normal topicRe: Auto define tracks
Yate supports AcoustID which is a fingerprinting service for audio files. There are a lot of options and automation support as well.
There is a main help topic called 'AcoustID' or you can do an AcoustID search via Help>Search Yate Help.
There is also a 'pre-installed' action named 'Unattended Metadata Lookups' which uses the functionality and is designed to be run in the Batch Processor.
I would recommend playing with the support in the UI before considering automation. The Actions>AcoustID menu is where you find the functionality. 'Fingerprint, Get Data, View' is a good place to start.
PaulPostFebruary 7, 2020, 09:19
Thank you very much. I will check it.
