Split Field action
UKenGBPostMay 17, 2020, 07:31
April 30, 2020, 09:36
Normal topicSplit Field action
The description for this states that both the source to be spilt AND the destination of the right hand portion be both Fields/Tags or both Variables. But the entry box drop down list for that right hand portion only lists Variables. There is no way to specify a field to use.
The source can be specified as a field, but the RH can only be a Variable and since that combination is not permitted, I can see no way to be able to apply the split to a field. It has to be copied first and everything done on variables only.
Whilst this can be done, it is NOT what the docs state. Am I wrong, is there a bug or are the docs wrong?
2MR2PostMay 17, 2020, 08:10
Normal topicRe: Split Field action
It is a documentation error. Track Variables are fields internally. However you should be able to specify the left hand side as a non-variable field and the right hand side as a track variable. If this is not working it is a bug...however it is working for me. Left me know.
The documentation will be fixed. I will look into allowing a proper field as the right hand side.
UKenGBPostMay 17, 2020, 10:23
Ah yes, I can do that. It was just the documentation that fooled me 🙂
Thanks as ever for the quick response.
