tnayakPostMarch 24, 2021, 01:24
September 25, 2019, 23:56
Is it possible to use an Action to create a New Lyric? The Context menu in the Lyrics(All) Panel allows you to create a "New Lyric" but i can't figure out how to do it with an action.
I want to search for better versions of the Lyrics attached to my tracks and be able to compare them to the current Lyrics to see which one is more accurate.
2MR2PostMarch 24, 2021, 06:30
You can create a new Lyrics item via the User Defined Fields statement in the Assignments category. Remember that the new Get Lyrics implementation will only write to the default lyrics item. This means that you'll have to preserve the old one before downloading a new.
Multiple Lyrics items are an ID3 thing. You don't have to use a lyrics item for this. You can copy the lyrics to a UDTI then have a custom edit panel displaying both copies... one in the real lyrics field and one in the UDTI.
tnayakPostMarch 25, 2021, 13:01
Is there a way to create the Lyrics copy without making the Default lyrics? I created the following action to create a copy the current lyrics and search for new ones, but am not getting the results that I expected - namely the "Original" description that I used to create the copy ends up being the description for the new lyrics.
ACTION
1) Run Inline action 'Search for Lyrics on Happi.dev' grouped
Run Grouped
Run Inline
2) Start Search for Lyrics on Happi.dev
3) Copy the Lyrics field if not empty to Variable 0
4) Import value of Lyric with name 'Original' from Variable 0 (create)
5) Get Lyrics using default settings, silent
Below is the info from the LyricsThe Action create a 2nd set of Lyrics (all) Edit Panel before and after running the action. I expected the Description for the Test Lyrics to be "Original" and the Default Lyrics (new search results) to be empty.
Lyrics Edit Panel - BEFORE Running the Action
Description Language Lyrics
★ <empty> eng Test Lyrics⏎Test Lyrics⏎Test Lyrics⏎
Lyrics Edit Panel - AFTER Running the Action
⚫ <empty> eng Test Lyrics⏎Test Lyrics⏎Test Lyrics⏎
★ Original Actual Lyrics
I inserted a Debug statement between Lines 4 & 5 and cancelled execution w/o running the Get Lyrics action. It looks like the issue is caused by the Lyrics-copy being set to default (per your reminder that that Get Lyrics only writes to the default lyrics item).
★ Original Test Lyrics⏎Test Lyrics⏎Test Lyrics⏎
2MR2PostMarch 25, 2021, 14:02
Hi ... it's just too difficult to see what is going on in a test representation. Please go to the Action Manager and select the outermost action which is called. From the context menu do an Export. You can ignore the first displayed panel. Choose to export as a zip file and email us the file. That way I can see what is going on.
tnayakPostMarch 25, 2021, 19:06
I got it to work by restructuring the action - details below in hopes that it helps someone else.
'Run each step in sequence for each selected track
'Start the action
'Store the starting lyrics in Variable 0
'Call the Get Lyrics process WITHOUT displaying alerts
'Store the Get Lyrics Status Code in Variable 1
Export the value of User Defined Text Item with nam 'Get Lyrics Status' to Variable 1
'Check if the Get Lyrics process completed successfully
'Verify that Variable 0, containing the starting lyrics, is NOT empty
Test if the Variable 0 field is not empty
'Create a new Lyric with the name 'Starting Lyrics'
Import value of Lyric with name 'Starting Lyrics' from Variable 0 (create)
OR
'Set the UDTI with the name 'Starting Lyrics'
Set the Starting Lyrics field to "\v0"
end if
end if
'Save the changes
Save the selected files if modified
Thanks for the suggestion about storing the starting lyrics in a UDTI and building a custom panel. Viewing the lyrics side-by-side makes it easy to pick the best one.
