Rename Template
UKenGBPostApril 8, 2021, 11:02
April 30, 2020, 09:36
Normal topicRename Template
Is it possible to use Folder Start in an 'If…' construct?
So the folder would only be created according to the 'If' condition.
I suspect not, but in case I'm missing something, would be good to confirm either way.
Thanks.
2MR2PostApril 8, 2021, 11:29
You're correct. Folder Start tokens are always at the root level. They terminate any open if sequences.
Path components are created when necessary for Move statements. The base path component of a Move statement can contain escape sequences. You can always use a Move which sets the base path at runtime and calls a rename template.
UKenGBPostApril 8, 2021, 12:36
No bother, I'll just have 2 alternate templates that'll be picked at runtime for each file.
