delete physical file then remove from the list
mrianforestPostJune 16, 2021, 01:21
May 25, 2021, 05:59
Normal topicdelete physical file then remove from the list
Is there a quick way to delete the physical file and then remove it from the list in Yate?
Right now I select a track, right-click...
show in finder
delete the file
return to yate
press delete to remove it from the list
It's a bit tedious...is there a faster way?
2MR2PostJune 16, 2021, 11:24
I am somewhat loathe to deleting audio files. However there is an action I've given out various times in the past. I've updated it and posted it to the resource web page. It's called Delete Selected Files. (at the very top of the action list). You can assign a keyboard shortcut to the action or associate it with a toolbar button.
The action first attempts to move the files to the trash. If that is not possible you get a warning to confirm the deletion of the files.
The file list is updated to remove the trashed or deleted files.
