Remove Trailing Character
lauriePostJuly 4, 2021, 08:30
July 27, 2020, 00:15
Normal topicRemove Trailing Character
Hi all,
I am trying to fix up some names of albums and tracks. They finish in a "." (full stop, period - whatever you call it in your country).
What I would like to do is have an action that will look at a field and loop till any characters that I don't want are removed. For example track-name..... Sometimes my father has put two, three or four.
Sorry I am trying to understand this but getting there slowly.
Laurie
2MR2PostJuly 4, 2021, 10:28
It's a period in Canada. 🙂
I've added an action named Remove Trailing Periods from Fields to the resources page. It'll be at the top of the list. It lets you select which fields you want to process the first time you run it.
lauriePostJuly 4, 2021, 19:18
Thank you. About to have a look.
You live in a lovely country. I hope the heat waves are over soon. Could not believe that some of the temperatures Canada has experienced are higher than Central Australia. Wow.
Again thanks.
