[Solved] Rename Error
DreamStaticPostOctober 30, 2013, 19:05
October 26, 2013, 16:46
Normal topic[Solved] Rename Error
Hello, I ran into a "Rename Error" during my editing. Curious if you might know how to correct the issue? I have some tracks that the id info is the same, but the tracks are actually two versions. Maybe one is a studio version and one is a live version. In iTunes it would just auto rename the filename by appending a digit so they could coexist in the same album folder. Thanks for the help.
2MR2PostOctober 30, 2013, 19:31
Normal topicRe: Rename Error
This is a common scenario. Many albums have multiple tracks with the same name. A good example is 'Intro'.
Yate has an <IfDup> token which you can place in the rename template. I tend to include:
<IfDup> T<Track><endIf> in my rename templates.
which in your example would have resulted in:
4 Minute 00.mp3
and
4 Minute Tnumber.mp3
You can configure it to do pretty much whatever you prefer.
I hope this helps.
DreamStaticPostOctober 30, 2013, 22:18
Hmm, what if you just wanted to use one of the variables and increment 1 digit at a time for instances where you don't have track numbers. Is that something that is possible?
2MR2PostOctober 31, 2013, 06:19
It's probably doable but would be convoluted. I'll see if there's am easier way to do it directly from the rename template. The issue is the looping for a valid number.
2MR2PostOctober 31, 2013, 18:52
I've implemented a <Dup #> token in v2.5.1 coming soon. The token will be replaced with 2,3,4,etc. until a unique filename is achieved. The token must occur inside an <IfDup> ... <endIf> sequence.
DreamStaticPostNovember 1, 2013, 00:22
WOW, that is pretty impressive response time. Thank you so much!!!
