Double Text
DJunpridictabullPostNovember 29, 2021, 04:52
Normal topicDouble Text
Is there a way I can delete the double wording and delete the Bpm's? I have over 1000 more that look like this.
Bar-Kays-Propositions (DJ Johnny Flores Edit) 140 Bpm (DJ Johnny Flores) (Clean- 140Bpm)_PN.mp3
Black Box-Strike It Up (DJ Johnny Flores Edit) 120 Bpm (DJ Johnny Flores) (Clean- 120Bpm)_PN.mp3
Bob Marley-No Woman No Cry (DJ Johnny Flores Edit) 98 Bpm (DJ Johnny Flores) (Clean- 98Bpm)_PN.mp3
Boyz II Men-Motownphilly (DJ Johnny Flores Edit) 114 Bpm (DJ Johnny Flores) (Clean- 114Bpm)_PN.mp3
Cameo-Back And Forth (DJ Johnny Flores Edit) 112 Bpm (DJ Johnny Flores) (Clean- 112Bpm).mp3
2MR2PostNovember 29, 2021, 07:08
There is more or less repeated text and you've supplied a number of before patterns. Please give an example of an after pattern.
I can't tell if you want all BPM text removed or which pattern of the text you want to keep: edit or non edit. Is the duplicated text always the same as in the above examples?
It can be done I just need a little more information.
DJunpridictabullPostNovember 30, 2021, 05:55
Thanks for the reply
Before: Bar-Kays-Propositions (DJ Johnny Flores Edit) 140 Bpm (DJ Johnny Flores) (Clean- 140Bpm)_PN.mp3
After: Bar-Kays-Propositions (DJ Johnny Flores Edit)_PN.mp3
It's hard for me to explain, but this is what I want it to look like. No BPM and double text.
2MR2PostNovember 30, 2021, 10:56
I've taken your example literally so please test. Download the file at:
https://2manyrobots.com/actions/DJunpridictabull-Rename.zip
Install it by dragging it to the main window's file list area.
You will now have an action named: DJunpridictabull: Rename
The action will be in the Action Manager and will also be available on the File>Rename>Actions menu.
You can rename it if you wish in the Action Manager.
You can run it as a simple rename on loaded files or you can run the action through the Batch Processor. Files which do not contain: (DJ Johnny Flores Edit) and do not end in _PN are ignored.
Again, please test.
DJunpridictabullPostNovember 30, 2021, 16:16
Thank you it works perfectly.
DJunpridictabullPostNovember 30, 2021, 16:42
How can I get it to change the title in the process?
2MR2PostNovember 30, 2021, 17:54
It's all in the details 🙂 To what... based on what? Exactly the same as the filename? Without the '_PN'?
DJunpridictabullPostDecember 1, 2021, 10:29
I got it! Thank you very much!
2MR2PostDecember 1, 2021, 11:41
Good stuff
