'N' lower case
J00pPostDecember 21, 2021, 10:50
November 25, 2015, 17:51
Normal topic'N' lower case
I would like to make the 'N' in Rock 'N' Roll lower case. Can somebody give a hint please?
2MR2PostDecember 21, 2021, 11:38
When renaming, in the Title field, in a genre?
J00pPostDecember 21, 2021, 11:50
Yes, I meant renaming in the Title Field.
2MR2PostDecember 21, 2021, 12:21
There are a number of ways to do it. Via the UI and via an action.
The easiest UI based method is to select all the files which might have a 'N' in the Title field. No harm will be done if they do not.
Click on the function button to the left of the Title field and select Multi Field Editor.... Select the Replace function. and set what is displayed in the attached image then hit the Replace Text button.
You can do the same with a one line action:
Replace "'N'" in the Title field with "'n'"
Note that there are single quotes inside the double quotes displayed above.
This can also be done with exceptions when you are doing case transformations and a variety of other ways.
J00pPostDecember 22, 2021, 04:14
All clear. Thank you!
