Unexpected result from previously working rename template
SnowdogPostOctober 17, 2025, 12:45
Hot topicUnexpected result from previously working rename template
I have a couple of "rename templates" that I use from time to time.
One of them is not working & I'm not sure why. There have been a number of Yate updates since I made them & I'm wondering if this might have anything to do with it?
As I type this, I'm hoping it might refresh my memory as to what I'm doing wrong! 😀
Here's what I do...
I move all the albums out of the music library folder to a new folder. (It's better to edit music away from the library & re-add it once done.)
I rename all of the folders so that they are how I want them to be in the Finder (First screenshot.)
I want the albums to be named exactly the same in Roon & Plex, so...
I load the albums into Yate. (Second screenshot.)
I run the rename template & get the error message. (Third screenshot.)
I can only add three screenshots so I'll continue in another post.
SnowdogPostOctober 17, 2025, 12:51
Ordinarily, the rename works & I then run an action to remove the last thing in parentheses, which removes the file format.
Done!
But, it's giving me an error & I wondered if you could shed any light?
As you can see from the first two screenshots, we're looking at a section of these albums where I've already done this. But I've added a few new albums & I figured it was just as easy to run the rename thing over the whole lot.
I can't remember how to call up the rename template so that I can see how it's built. (It's all "tokens" or something. I can't really remember now.)
Anyway, this is what it's called (& it usually does exactly what it says on the tin!):
SnowdogPostOctober 17, 2025, 12:58
Okay, I found the rename template thingy.
It says this:
SnowdogPostOctober 17, 2025, 12:59
I still think I'm waiting for a penny to drop in my brain & I'll go "bugger, I know what I'm doing wrong!" 😀
2MR2PostOctober 17, 2025, 15:12
LOL. So is it all good now?
Make sure that you're running Yate v8.2.3.1. Yate v8.2.3 had a pretty bad bug.
2MR2PostOctober 17, 2025, 15:20
Just in case ... and I'm a little fuzzy today after a long lunch ... Your rename template has no folder specification after the (folder start)
SnowdogPostOctober 17, 2025, 15:43
Ha! No the penny hasn't dropped.
I am running the latest version.
It's always worked before & I've never knowingly changed it but I'll have a play.
2MR2PostOctober 17, 2025, 15:49
Well the error message is that the rename template is invalid. You have an empty (Folder Start) token in the template ... it should be followed by a folder spec. Basically the template is attempting to rename a folder component to empty.
(Album)
(Folder Start)
will rename the filename to Album and then get messed up. What are you actually trying to rename and to what?
SnowdogPostOctober 17, 2025, 16:43
I want each album title in the album field to take what I've written as the folder name in the finder & use that.
As you can see in the first two screen shots, it's done it correctly for the first 5 albums (apart from the fact that I've then gone in & removed the file format in parentheses).
So the first album is "Fading Memories". I've named the folder how I wanted it to be in the finder (including the file format AIFF), run the rename template to change the Album field for each of the tracks in that album & then removed the "(AIFF)" using an action you wrote.
I haven't changed the rename template. In actual fact, I can't believe I ever managed to build any of the rename templates in the first place. But I was younger then & full of hope. 😆
SnowdogPostOctober 17, 2025, 16:50
As you can see from these screenshots, If I go to the bottom of this album list where the new albums are, I've renamed the folder names in the Finder with the album titles how I like them to be.
(First screenshot. The big clue is they start with release dates & end with the file format.)
But the albums in Yate (second screenshot) show them as they are currently tagged. Usually I would run this rename template & use the Finder's folder names for the Album field.
