Pages: 1 2 3
Retagged folders wont play on a CD
2MR2PostOctober 14, 2016, 16:38
Very Hot topicRe: Retagged folders wont play on a CD
I'm sure it can. We have still not eliminated your car's CD player. Can you play the CD on your Mac?
offtheroadPostOctober 14, 2016, 17:28
September 3, 2015, 14:04
It will play on my Mac but not in Car. There aiff's If I try to select different tracks in car it just stays on 1. Other older copied CD's will play this was before I learned about tagging. I'm not blaming your product. I'm just doing something wrong.
2MR2PostOctober 14, 2016, 21:07
I wish I could help but I can't figure out what is wrong if the Mac sees everything okay. 🙁
offtheroadPostOctober 14, 2016, 22:13
OK thanks,is there any others you can ask? You guys have helped me plenty. All this music I set up and collected was just for in house use on my DAC but I thought I might want to listen in my car I drive many trips up to Colorado Springs from Albuquerque 6hr's to help my daughter she has two special need kids and need much help when she takes one to the hospital or coulseling..
2MR2PostOctober 14, 2016, 22:20
Let's eliminate the CD burner software. As your files are AIFF, they can be added to iTunes. If you add some of the tracks to iTunes you can try burning a CD with iTunes. If that works we'll know that the issue is with the software used to burn the CD.
offtheroadPostOctober 14, 2016, 23:37
OK Still use the LG burner/Player because the superdrive in the Mac (why do they call it that?) instead of a burner? I'll try.
offtheroadPostOctober 15, 2016, 15:02
OK so I had to import audio files into iTunes and make a playlist burn from there then it would play in Car, but back to the same old crap with iTunes not naming track titles. Thanks
offtheroadPostOctober 16, 2016, 00:24
Problem solved, doing it the hard way copy and past.
offtheroadPostOctober 16, 2016, 00:25
Pages: 1 2 3
