Pages: 1 2 3 4
Any tips for Initials?
ZipaulPostFebruary 26, 2014, 09:19
December 5, 2013, 19:18
Very Hot topicRe: Any tips for Initials?
The contents of the title are correct, but all toghether......no artist name tough in the Name section. And to extract the metadata, I already have a template: put the track in Itunes, drag it to Yate, and apply the template. Works perfectly. But here, as I have no artist name, do I have to go 1 by 1 ??
2MR2PostFebruary 26, 2014, 13:25
Okay you can find a 'one-shot' action here:
http://2manyrobots.com/actions/Zipaul-20140226.zip
This will only work if the first two components are the Artist and the remainder of the filename is the Title!!!!!!
1) Unzip the archive and import the file by Yate>Import Preferences.
2) Load the files to have artist and title extracted.
3) Select all the files to be modified
4) Action>User Defined>Zipaul-20140226
This will extract the Artist and Title fields from the filenames. It does not save the files!!!! I did this on purpose in case you don't like the results. Once you have the ARtist and Title fields you should be able to use your existing rename templates.
ZipaulPostFebruary 27, 2014, 05:51
Simply wonderful !!! Thank you very much. Paul
ZipaulPostFebruary 27, 2014, 05:58
Just one more thing.....could you please send me a template that only changes underscores by spaces, please. Thanks again. And have a nice day.
2MR2PostFebruary 27, 2014, 07:27
Download the action at:
http://2manyrobots.com/actions/RemoveUnderscores.zip
2) Load the files to be modified.
4) Action>User Defined>Remove Underscores
The action will replace underscores with spaces in: Artist, Album Artist, Album and Title
You can then rename however you wish.
ZipaulPostFebruary 27, 2014, 10:33
Thanks one more time. Paul
Pages: 1 2 3 4
